Just wondering wat PSI I need to put in, they are 205/40/17 as I am goin on a long motorway drive tomorow an they are a bit flat at the mo.
Also they have rubbed a huge hole in my front arch liners, is it bad??
Yes it is, your arch liners are protecting your fuel lines, if you go through one of them your car will explode into a ball of flames, stop driving it immediately and get it checked out
their aint no fuel pipes goign to the front wheels !!!! silly terrorist. its just where u turn i take it, and has worn the plastic linner, correct ? just get some new ones from a scrap yard, and let them wear out again, not much or an issue
Usually you just keep them teh same I thought, so 32 front and 29 back
My 185/55/15's are 32F 29R, surely 205/40/17's should be a lot higher?
Thanks ppl.
And If I blow up in a big ball of flames like Terrorist seams to think I am blaming you Alex!!
Thanks ppl.
by the time you have driven to the petrol station or whatever your tyres will be hot.. put 36 in the front and 34 in the back... when its cold this will be about 32 - 30.. buy a decent pressure gauge too to check overnight
