Can some body give me a part no for this?
Car  Valver
Valver 92 plate, the bit in the arch that clips the brake pipe to the inside of the arch to stop it rattling about? Its located pretty much directly behind the shock on the road-wheel side of the arch!
Cheers ;)
because there thick and untrained on the dialogys
Shag no not that one I bought one of those today.. just realised I described it totally wrong! Its further up the pipe by about 15cms and it holds the pipe against the arch?
No can't get one at the mo as Im at work... I'll try describe it better...
Where the brake pipe comes out the engine bay and into the arch by the wheel it goes through a clip on the inside of the arch which holds it against the arch and stops it flapping about, from there about 10cms further on, it connects through a clip to the brake hose itself (part of that clip is arrowed above) but its not this i need, its the clip before it which holds the pipe to the arch!
