taking out and putting in 182 seats
Car  missmy257bhp r5/ got evo6
hi have a 182 ff and i have the recaros out of my old cup how easy is it to change them over i have heard its just 4 bolts under the car and the air bag plug under the seat
is it that easy
ps when you disconnect the bat for the air bag plug is there any time delay if so how long as i dont want to pull it apart and they go off
many thanks rich
I always leave it about 20-30 mins between disconnecting the battery and touching anything airbag related.
Yeah 4 nuts on the studs that hold the seatframe in that you access from under the car. Outer ones have grommets covering them and the inner ones dont (there's potential to cut your fingers to ribbons on the cat heatsheild which has cut outs to access them). Disconnect the battery then seatlooms then 4 nuts and out it comes.
as loony said, its just four nuts under the car for each seat and undo the teo clips for the airbag and seat pretensioners :)
have you got resistors ready to put in for the airbags?
many thanks mate some one told me u can do the air bag straight away after you disconnect the bat
good thing i did not
sorry mate dont want to sound like a numpty but what are resistors
as the recaros are out of my cup i thought its just put them in and plug the air bag plug into the recaros as they have the same plug on them
ps i know recaros dont have air bags but def has the plug
It's unlikely it'll go off but tbh I'd sooner disconnect it and allow any residual charge to dissopate than dive straight in then somehow trigger it. I've seen a guy work on a dashtop without disconnecting a battery, airbag went off and put his head through the windscreen!
You'll need a deep socket and a small extension for the ratchet from memory (been a few months since I did the job)
cheers mate what does that other member mean about the resistors
the recaros are out my 182 cup so should be a straight swap
is it??
iirc matey when you disconnect the side airbag clips from the seats in your full fat you will need to put a resistor in each side to stop the airbag light on your dash coming on seeing as your recaros dont have side airbags!
i had to do this with my misanos and im sure its the same for the recaros
i used 3ohms resistors (i think lol) and they were 15p each from maplins
a school boy error on my part i never disconected the battery when i put my seats in . lol . but i will when i take them out . cheer's fella's
as long as your careful there shouldnt be a problem! i didnt disconnect my battery either :o
http://www.cliosport.net/forum/showthread.php?t=127019&highlight=airbag+resistor
theres a bit of info in this thread matey! if the seats already have a resistor kit on them then there will be no problem! if not then you can buy a recaro kit for 20 quid or 2 resistors for 30p or go to a reno place and get then to turn the side airbags of using clip
many thanks mate doing it sat
does the 182 cup have the same wiring as the 182 ff
as they are from my 182 cup i hope the recaros have the kit already
but 30p is ok
if your cup came with the recaros then im not sure whether reno would have fitted a resistor kit or just turned off the side airbags with clip
so it depends on what they did really! but if you do need to put resistors in then its only a small job to do
cheers i guess i will find out sat then
ps the recaros came in the cup from new
Any pics of which holes to put resistors in as my serv light has been on for ages now. Would be nice to extinguish it.
i havent got pics but if you get yourself 2 resistors then have a look at the air bag plug you can pretty much see where to stick each end of the resistor! i stuck mine in , the light went out and i secured the resistor :D
no i want to keep the rear leather even thought the match is not great
i now have an artic like yours love it its all cupped up
So your inferno will have full fat seats in the front and poverty spec cup bench in the back .. :eek: that surely won't help the sale will it ??
Nah i'll get the full fat seats in mine and the inferno will get my cloth ones.
I'll buy the back bench later.
I hope this is going to be an ok job:dapprove:
hi guys put the seats in now it looks like the recaros did come with resisters but i have pluged them in and the service light is on
what is that clip all about
will renault charge much
clip is the name of the system which reno use to plug in to change/check the settings on the ecu/onboard comps. they can plug it in and turn off the side airbag lights ect
renault take the piss but if thats what needs to be done then will have to do it
when they use clip do ypu need to buy resisters aswell or can they just turn it all off
chears mate do all renault main dealers have the system
im not sure but i would assume that all dealers with servicing departments will have it :)
if some main dealers are arsey about doing it for you or want to charge you loads then find a local smaller dealer and they will probably be happy to help if you pass a bit of silver across their palms :D
cool cheers mate the main dealers love to make money off us
round here there are no small dealers
thanks for all the help will give them a go
just spoke to my dealers round my area and they said they would not do it as i could take them to court if i had a crash as the side airbags would be turned off. recaros and cups dont have side airbags there must be a setting
MY RENAULT DEALER IS GAY
Take it a small garage could not do it????
if its a renault one then it should be able to do it! im not sure about other garages tbh as i would assume the system is specific for each manufactorer
thats sh*t news dude
are you anywhere near the like of mike at rentech or gdi etc! they might be able to do it?
dont know where they are
i am in kent
dont mind traveling a bit
i am keeping the recaros no mater what
just want yhe service light out
my dealer wont even let me sign a disclaimer to do it
get nothing from my local dealer they never want to help
what do renault do when they put the recaros in
will do
i am sure it will get sorted one way or another but the recaros are not going anywhere they are out my old cup so they must work
i would rather have the light on for a few weeks than go back to standard
cheers for all the help mate:)
basically they are just being arses! the trophies and recaro spec clios just have the side airbags turned off by CLiP!
they are just being knobs by not doing it for you! i bet if you bought the recaros from them, then they would happily turn it off for you!
its all about the money with the damn stealers
