mk2 172 Acoustic Valve Meant to be Open or closed
Yesterday i took off my wheel arch liner to have a squint at the acoustic valve and upon removing the pipe coming out the bottom of it i noticed the flap was in the open position (with engine off).
Is this correct or is my valve faulty ?
As i thought they only opened when they reached a certain rpm and closed at low speeds...
Can anyone help ?
len_beach
  E92 M3,172 track car
I don't think they open until about 1800 rpm. I'd remove it anyway as they do nothing other than supress noise and restrict flow.
  182 inside
take it off, you'll notice a change, while your at it, bin one of the horns and the extra bracket for it. small weight saving
take it off
I removed it on Monday afternoon after getting a metre of 60mm ducting pipe from local truck/van dealer down the road and the bloody snow started :mad:
I also did the Ecu Reset, where when you start car afterwards it sound like a computer starting up..
Unsure if its made any odds though :S
Maybe the throttle is more responsive or maybe i'm just thinking that
Pics.
Acoustic Valve Removed left standard airbox feed from top of it. (Inside Arches need a clean though:dapprove: )
Electrical Connector taped up and brought to engine bay and put inside fusebox and vacuum pipe plugged and tied back out way
Heres the New Air Feed in place
New Feed behind Grill
Must admit though my acoustic valve looks better on shed floor where it landed when threw it in after i took it off :) LOL
