no rubbing at all mate.looks wicked JAse - any rubbing with the spacers? the wheels stick out a lot now! did H&R do a smaller spacer by any chance?
aahh! 15 and 25 per side.that makes more senceoh ok, i´ve mounted 15mm per wheel at front.
25mm looks better
ok very good, a friend of mine attached the cup exhaust on his 197, ... that´s intolerably loud
yep the rear clio badge is just stuck on.removed rear clio badge. <<< is it just stuck on???
oh! and renault sun glasses holder(replaces grab handle)
jase... <<< not sure what you mean? pic?
tbh i doubt that the rear diffuser does that much?looks great. but is the diffuser working properly with exhausts sticking out, is the car harder over bumps i.e less forgiving on b roads / wet due to lower and spacers.
i.e its a slow`ish car so handlings what its all about, havent renault got it all right ? the meg isnt really low but a good bod of mine on meganesport assures me the setup is so good his noble would have a hard time catching it on the twists (would get raped on a track though lol)
no problem pal.cheers
cheers pal...yep thats the same as my sunglasses holder that replaces the grab handle.available from dealers.looks like that
cheers...Best 197 I've seen.
Hope you don't mind me asking but how much did JBS charge for the suspension mods?
...is the diffuser working properly with exhausts sticking out...
not that i've noticed,i dont drive it like at tw*t;on the limit everywhere i go....is the diffuser working properly with exhausts sticking out...
That's what I was thinking. I bet the arse end is all over the place with all that downforce gone!:boring:
nope(presume you mean undernieth)...and same here,i thought it would need to be scraping the gravel to create any usable downforce too.Looks like an ace car.
Renault claimed the diffuser meant you didn't need the rear spoiler, so i guess it must produce some downforce, but from the little i know about aerodynamics i think they only work properly when the car is very low to the ground.
Does the 197 have a flat floor?
i guessed as much.I was kinda joking, as I think we all realise that the diffuser probably does very little
Cracking looking 197, although the best colour for that car is silver IMO![]()
