info needed. new sonus pc.
Car  182 CLIO SPORT
Hi there. ok i've just got my new sonus pc and will be attacking the car this weekend. Will be usen grey sonus clay bar with chem guys QD. That bits ok but help needed here. i'm going to tape all grills and gaps up etc. With the sonus yellow pad i'm going to use chem guys lazor buff, then white pad with AG resin polish then blue with AG egp. after that the chem guys 50/50 wax is going on by a sonus der wunder applicator. If this is totaly wrong can you put me right lol. :D
Thanks
garymac.
Order sounds fine. Not sure on how much cut the lazor buff has but it is always worth trying the mildest combos first on a polishing pad before you step up and use cutting pads.
Spot on rich cheers. so do you think i should forget the yellow and start with the white??
I always advise people to get two or three of each pad for this reason, especially the polishing grade.
Would see how you get on with the polishing pad first yes.
Top man thanks. i'll order some white and blue sonus pads right now.
