172 rear wheel bearing?
H
hoppyuk2
about 40 pounds each u may aswell do the discs aswell if replacing the bearings dryclough lane garage renault specialists in halifax stock them cant remember number sorry
  172 cup'd extreme
geniune ren is 77 01 463 523
Thanks! May I know how much for the geniune one??
And what other models share the same rear bearing?
Plus, why rear one worn faster than the front? Is that common?
Hi Bill, the rears wear faster as they take a lot of load when cornering, they are also thinner than the fronts.
the UK price is around £40 but you can get them here for less ( non genuine types)
Its a common bearing i dont know exact cars but its used on saxos, 306's and 106's and also williams and and valver type mk1 clios
also here a disk with the bearing pressed in and an ABS ring is around £70 so its usually better to buy a whole disk.
