Gilmour Foam Gun
al
Car  ST on the way...
All I can say is WOW!!! :cool:
Used it for the first time today with some "Snow Foam" and what an amazing job it did :D
Piccys will be up soon... ;)
The snow foam seems very gentle as well as far as the wax is concerned, water still sheet/beeded off nicely when rinsing the foam off :)
mine just needs a new adapter to connect to the hose cause every time i use it i get soaked
so im assuming you could rinse your car using normal shampoo or snow foam etc, then wash the car with a mitt -bucket as the shampoo is on the car then rinse off with normal water?
is that best/right process, so the only real plus is that you dont have to use a bucket?
Super snow foam in the bottle :)
I dowsed the car with the foam and let it settle for a few minutes, then fully rinsed the car and went onto a normal 2 bucket clean :)
I have the origional design one with the brass adjuster, dont think you will go wrong with either.
