Redline Shockproof gear oil - anybody use it?
Car  RSC 182 Cup
Do you guys get Redline oils in the UK? www.redlineoil.com
I've used their Shockproof in a couple of cars with great success (improvements in shift) and was thinking about putting it in my Clio box. I was wondering if anyone had tried the Shockproof range and what viscosity they used- Superlight, Lightweight or Heavy?
http://www.redlineoil.com/products_gearlubricants.asp?categoryID=6&subCategoryID=16
IMHO it should almost be possible to get away with the Heavy - and it would provide maximum protection over the lighter grades??
The Heavy can be rated as a 75W250 Gear Oil, but has the lower internal fluid friction of an SAE 75W90. The LightWeight can be rated as a 75W140 Gear Oil, but has the lower internal fluid friction of an SAE 30 motor oil. The SuperLight can be rated as a 70W90 Gear Oil, but has the lower internal fluid friction of an ATF.
Have you thought about the Shockproof instead? IMHO, after using both types, it's better (and I wish I had got the Shockproof instead....) And they cost about the same. That's comparing the Shockproof Lightweight to their MT90 in a Daihatsu Feroza gearbox ("Sportrack" in the UK.)
A lot of modded WRX owners swear by the Shockproof and claim it saves their gearboxes.
