nattys blue
Car  Monaco 172
i got some of this for my monaco blue, as i found it impossible to find anywhere selling that p21s stuff. and im impatient and want it for weekend! :) how do you go about applying it, or is there decent instructons with it, got foam pads and microfibres at the ready. and do you leave it on for long or on and then off again?
cheers
One pannel at a time, i apply with a foam applicator pad, usually a megs one. Apply as thinly as you can as anything that is buffed of is wasted product.
I usually remove with a plush micro fibre cloth
as below but may want to use a QD to help remove it. Dont do it in direct sunlight either
Spritz the foam pad with a spritz of QD. One wax I am really not a fan of - even a panel at a time it is not as easy on or off as other Carnubas.
do you mean spray a weee bit of QD on and then put the wax on and then onto the car? (novice with waxing!)
Nice depth, however you will have to do the same a week later as it will have dissapeared.
Did not even think it was that good depth wise. Vey wet but I always had to use another wax after to gain the depth - now just don't bother with it.
Yes - Dampen the applicator first with some QD before putting it into the wax.
