Were can I find those topmounts??
I was just going to ask, Where can you purchase Mounts from? Do you have to get em from Renault?
How much are they each?
Are they easy to fit or does the Engine have to come out or be lifted?
Read posts 1 and 3....... £20 and the part number is there too.
ive got play in my steering,valver,has any1 heard of this b4
is there anyway of changin this with out disconnecting the battery? i dont want to lose of all head unit settings?
iv taken my battery off 3 times now mate and iv not lost my rad settings
Not had my 172 for that long, and have noticed a similar problem, but it doesn't sound quite the same... I also get the same sort of repetative loud knocking under hard acceleration, however the difference is, it only occurs when the front wheels spin (easilly done in the wet in 1st gear!).
I can accelerate as hard as i like in 1st and its fine, so long as the front wheel have traction. Could this be caused by the same engine mount problem discussed earlier? Is it more likely to be something else? Suspension? Subframe?
Most likly your dogbone mount is worn its a common issue new ones are only £20 or so and easy to fit.
