172 on a diet
Car  C63 AMG, F430 & 172
so far ive managed to loose 140 kgs of s**t from my psh1 172.
what would be the new wieght? i.e what are they standard. just note to loose this ive lost
Aircon pump
aircon lines
aircon rad and condenser
standard battery for race batt
front t-piece
steel bonnet for fibreglass
inlet manifold ;)
plenham ;)
air box and bend
standard system for custom lightwieght job
carbon canister
all interior inc door cards, roof lining (replaced seats with susukas)
PAS pump
Pas lines
Manual rack - fitted
All AUX brackets and mountings
Ecu tray and mounts
ive weighed this in at 140 kgs!
bhp / (wieght ton) = bhp per tonne
to work out the wieght in tonnes take the kg weight and divide by a thousand.
/ = divide.
p.s ill ring ya in an hour..
just divide the bhp by the current weight of the car, which works out the bhp per kg, then times that by 1000 (number of kgs in a ton)
im using f4r by the way too. no VAG etc.. just a "tuned 172 lump" and its not a dirty turbo:dead:
anyway moving on. you will all have to wait 8 weeks.
cheers for the power to wieght stuuf
wont be NA, will be charged. if it's NA it wont last long at all.
charged with bottom end mods, cams, larger throttle body or ITB's will easily do 400+bhp
lol.
I like your style it will be the most tuned renault engined 172 by far. I think give you another couple of weeks and you will be fitting a turbo aswell ;)
im not sure Mark. ive heard a load of horror stories about the omex in the last few months.
plus im not sure it will run all the "parts"
this i am at a loose end
lol, well I think I have an idea on what you are going for... charged for sure, ITB's as well as some bottom end work. Would have thought an Omex can run all that no problem and not really heard much about problems with them... if mine ever broke I'd just speak to Richard at Omex and the problem would be sorted out almost immediately :)
