home made IK
Car  172 ff silver
im thinking of making my own induction kit relocating filter behind n/s headlight using stuff from merlin :
http://www.merlinmotorsport.co.uk/SAMCO-HOSES/c16/index.html
what do you think? will it work ok and will this filter do the job or should i go for a cotton type filter instead of the foam ?
i will also need a cranckcase breather filter (what size ?) and a cold air feed from front grille
any comments suggestions welcome :D
it'll work i've relocated my filter behind the headlight and its a lot better. i've got the phase 1 though with the vents next to the headlight.
I was going to say the similar... get yourself a 172phase 1 airbox and just get some cold airfeeds going direct to it. I have one spare with an itg panel fiter and two 80mm airfeeds if you are interested.
the phase 1 air boxes are good very similar to an itg maxogen but just too quiet for me. :( i suppose its what you are looking for... ultimate power gains or for it to scare people when you overtake them lol
Go for it mate . You'll most likely get slagged off for heat soak but i doubt it will suffer any at all . I looked at ITG foam filters before but i wasn't sure on the actual size of the filter so i opted for a green cotton filter . I suppose you could always ring merlin and ask them how big they actually are .
Why the reducer though ??
its 70-80mm as the flange on the filter is 80mm where as the rest of it is 70mm
dont spose it matters really just get a 70mm flanged filter and do away with the reducer eh ?
also what size crancase breather do i need to fit on pipe from crankcase ?
Just go for one with a 70mm inlet , if you get a reducer you'll also be adding to the length of the pipe and might struggle fitting the filter in . Off the top of my head its 14mm for the crankcase breather pipe .
as for length of inlet, iirc a longer inlet path makes for improved torque so i might gain some torque maybe
I was just thinking you'll have two 90 degree elbows then a reducer inside the elbow going behind the headlight , this might make it a bit too long and push the filter too far towards the wing , unless of course you cut down one of the 90 degrees . I'd just stick to all 70mm , elbows , alloy tube and flange size . Plus it saves you a few quid not buying the reducer .
Your idea is an option i considered before making my custom airbox .
I'll be interested to see the results :)
yeh mate i think sticking to 70 mm makes for less hassle
and i will cut 90 bends if i have to because i dont want it to far towards the wing
think it 70mm lol can check if u intrested only after tenner for it and u only live in stafford im from stone
nah is there a meet our sumthink? were bouts in stone ya from i live on cherrfeilds ? were ya house in stafford
