was when i stripped mine.
4 bolts on underside of car, extended 13mm socket i think disconnect wires (disconnect battery long before you do this though),
Yeh, was just reading a guide on v6clio.net. All four bolts are under the car aye?
do you have to jack it up and put it on axle stands?
just unbolt it from below, 13mm deep reach socket, maybe an extension bar. probably takes longer to jack each side up and put on axle stands than to unbolt the seats.
I normally leave the battery off for 30 mins.
How are your seats fitted? subframes?
Bear i'll bring ma grinder, that boys plasma cutter and your maw can weld it all up, done n dusted in about half an hour..
I can even solder up the airbag connectors if need be..
I did cos Im too big to fit under the sills properly!
must give this a blast too, cause my driver ones rocking back and forward ever so slightly, its just annoying more than anyting else.
Recaro Pole postions, straight out of ColinG's old V6...So it should be a simple swap!
