what happens if the aux belt / pully fails
Car  C63 AMG, F430 & 172
A friend called me saying his car had broken down and would not start.
I had the car delivered to my house on Sunday morning..
normal 172
window washer jet unclipped
bonnet off.... much better for access etc
engine cover off
checked the aux belt.. why is only half there?
Pelham, coil pack, map sensor, air temp sensor, ICV sensor, TPS sensor and throttle cable removed
Arch liners, sump pad, upper grill, bumper, fog light loom, T-piece slam panel, injection rail protector, wheels off and car jacked up on stands
Yep defiantly only half the AUX belt..... ekk
Ohhh the pulley has lost its bearings and sheared from the end-case........nice
Aux belt removed..well one side of it, it looks like a piece of string lol...wonder where the other half could be? :S
Oil separator and solenoid valve for the VVT removed.
Coolant drained, temp sensor unclipped, loom clips and earth detached from head and removed the top alternator bracket and the lower inlet, fuel rail, injectors etc.
Top suspended engine mount removed and cam belt cover (supported engine on jack)
Oooooh...............found the other half of the aux belt wrapped around the inlet pulley
Now I couldn’t remove the pulleys as the belt had snapped! So they would just spin! Ahhhh! So after a lot of faffing about and tapping with a rubber mallet I got the rover cover off!
My ingenious way of not losing the tappets original places! Fitted each one in a money bag and labelled to each corresponding fig on the diagram.
All the bolts bagged up and marked in order!
Cracked the head bolts loose,
Removed the head :D
11 bent valves
And one nicked piston
And a few “before hand shots of the head ports” roll on BenR port and bowl headwork! It’s also having cams, inlet match, remap new gaskets, and a few extras :D
Watch this space
Ouch! And the muppet at Renault was convinced when I got my 172 that if the aux belt went it would most deffo not take the cam belt with it! He was convinced that it was ok and if the aux goes, the cam is protected as its incased. I might email him a link to this thread (yes, this is a service manager!)
They did do the aux belt along with the alternator after it burnt out on day 4 of ownership! grrrh!
@Mells - its well known that if the aux belt snaps it will more than likely take the cam belt with it.
@Ben_P Nice one for taking all those photos and posting this up, it goes a long way to showing people how important having the belt changes done on time is on the 1*2s
I agree fella. It was trying to convince a service manager that that was the case. He was under the impression that they only need to be serviced every 18,000 miles and both belts doing at 72k (very old renault info). Apparently, they service at least 2 RS a week so he knew what he was talking about :clown:
Jeez that did alot of damage! Had mine changed along with the cam belt at the 72k/5year service, cam pully I assume?! is still squeaking on cold mornings though :S
you need the locking tools to get the pullies off, check you haven't damaged the rocker cover
it came off fine in the end, no damage to head r cover
i have all the tools bar the pulley one :(
ben is lending me his to re-time it
Nice work, he/she made a good job of that. That idler always seems to be a weak point, its a bit exposed to the elements all the way down there.
How many miles has it done??? Thats the cleanest valve cover ive ever seen, normally they start to leak oil up through the bolts.
Good reason there to have the aux pulleys changed and not just the aux belt like so many people have done. from my experiance (all makes and models) its 90% of the time a pulley failure not the belt. Seen that lower pulley fail many times on megane's etc. sometimes takes part of the sump with it on those
This thread should be a sticky as a warning!
69k mate, its been off before for the cambelt
Had it done many miles since the last belt change? Glad I got my belts and pulleys done a few months back after seeing that.
I agree with Burp this should be stickied as a warning for other members.
im not sure of the history
but it was a very old belt, what was left of it was in a poor state (cracking when bent, very dry, could pick bits off it
that car looks familiar lol. nice one for doin this m8, cant went until its finished and back on the road with all the extras. cant wait to get those coilovers on on saturday aswel.
