what fuel do people use in their 182
Car  none :(
Does it really matter what fuel you use, ive read some people use v power, but can you just use normal pikey petrol (is it ron95 or something like that)
does using different petrol make that much difference.
Optimax/V Power from new, as to making any difference I don't know for that reason.
But as the fuel flap says it needs super that's what it gets ...
99 grade fuel, usually tescos. Mine tends to smoke when i boot it if im using anything else :rasp:
My expression says unleaded, so thats what it gets. :p
Clio's are mapped for 98RON so anything higher is pretty pointless unless it's been remapped for it.
i get better mpg on 95 ron, i used to use 99ron but heard some bad stories about it and its stupidly expensive for the ammount of miles i do
normal sainsburys derv ive run it on bt ultimate derv but i dont think i saw much diffrence
:o but ive just reailsed its about 182s
bet you have only been to fill up the once since new???
I use v power, it just feels smother and as more lower down torque. When I was running it on 95ron I was getting something like 25mpg I get 30mpg with v power.
The Vee feels better on the more expensive stuff - so that's what it gets, and I do sod all miles anyway so it doesn't really matter heh.
Dan
98 ron on the flap i think refers to research octane number which is similar to 95 ron (road octane number) which is just standard unleaded.
read a thing somewhere that a lot of fuel companies deliberatly mix these two figures up to sell their "super fuels" apparently the 98 RON v power is the research figure not the road figure.
regardless of that i still use vpower it's only a couple quid more per tank
i siphon it from other clio's as we all know the clio "key" trick...
its cheaper that way...and gives you a right buzz...
n e thing above 95. lowest is jet i think at 97. id prob put 95 in if i had to....it does make sence in this stupid country with its stupid fuel prices.I cant believe how our government constantly takes the p*ss out of us all 24/7 and we just seem to take it!:mad:
