Paintwork f***ed once and for all? Fred?
Tighten My Nuts
I've been running PF97 pads over the winter, and the car's not had a proper wash for weeks.
Stuck it through a carwash today, and the sides of the car remain covered in brake dust.
Fred - you've got some miracle cure for this?
MRBILLYUK
  FF Jeden Osiem Dwa
Fairy power spray ;) If it's really bad you might even be looking at clay as well .
Daniel
  Whichever has fuel
Wet n Dry the affected areas, polish back up with a machine polisher.
Bob's your monkhouse.
Ali
  V6, Trackhawk, GTS
LOL @ askin advice from fred.
Mark Autosmart tardis is a good option. But PF dust is brutal!!!
  Shed.
Clay
Try some other s**t, like super degreaser or how about wheel cleaner, tho not on your paintwork lol.
MRBILLYUK
  FF Jeden Osiem Dwa
^^^ Why not . Paintwork on the body is the same as on your wheels , paint and lacquer .
  VRS
had the same issues with my carbon lorraines fella, came off easily with the megs clay which you get in their detailing kits :D
the sonus green was a little too mild
andy
  VRS
how does that clay s**t work i want to try it but dont wanna fuk my paintwork up?
you apply the detailer which acts as a lubricant, gently pass the piece of clay over the lubed up bodywork and it picks up the contaminants
to a search for claying on here and you will see loads of info and tips :D
  CS Dungeon
Ignore him, he's talking out his arse, I dont act as a lubricant:rolleyes:
I think he meant quick detailer;)
  Lionel Richie
i used wonder wheels on yoz's cup before taking it to the shows, works fine, just rinse the fucker down properly
  53 Clio's & counting
bad for you for takin it through a car wash! lol
i sure hot water will get it off,worked for me in the past matey
cg172
  Clio 172FF
You could try using my lass.
She spent many a happy hour picking the tar splats off the sides of our old dynamique while I was washing it. Did a good job too! :D
  RenaultSport 172.
had this exact problem with my mates carbon lorraine pads.
spent about 10 hours with autoglym paint rennovator rubbing and the likes, then had to clay it...still not perfect either!
