On a 172??I have 17's and it's lowered 45-50mm on eibach sportlines.
Handles much better and theres no rubbing whatsoever...
Although I had 5 people in the car and a full boot once for about 5 minutes and it didnt look too healthy![]()
All to do with being female IIRC.Whats the verdict on lowering???
Ive got a Ph2 172 on 17's, and wouldnt mind lowering it tbh, but worry about the handling. Already having problems with tracking/steering but will sort them hopefully! just wondered what people thought?
No offence, but no way in hell do you get a 50mm drop on eibachs with a 172. They drop 50mm on a standard clio, the 172's are lower as standard. Apex only give 40mm, and they're pretty much the lowest you can go with just springs.
Amen. And rofl.It says 50mm drop as they suit many clio's. As sports are lower as standard they lower less.
If you put those springs on a non-sport (which it also says on the product info they will fit) you'll get a 50mm drop.
Erm, rofl.
Im even more confused now LOL!!!
No offence, but no way in hell do you get a 50mm drop on eibachs with a 172. They drop 50mm on a standard clio, the 172's are lower as standard. Apex only give 40mm, and they're pretty much the lowest you can go with just springs.yeah...
Definately lower!
If you need someone local-ish to fit them I can do it for you, won't take long!
Definately lower!
Oooooooooh!!! Can you recommend anywhere to buy some and what size to buy? (i know Nooooooooothing!!) May be beers in return
lower it lol dont need our vote its general cs knowledge![]()
handing shouldnt be an issue when you got a maxi-cosi:rasp: 20mph max for you mrs Olower it lol dont need our vote its general cs knowledge![]()
ssssssh!! i know it will 'look' better lowered - i was concerened about the handling! Mmmkay!? :rasp:
lol . . . dans les deux cas, vous avez un carseat. . .vous devez conduire comme une grand-mère :rasp:Maxi Cosi??? Pffft baby recaro ftw lol!!
just had my 182 fitted with eibach sportlines 30mm and 17's. i get rubbing on full lock and on turning on uneven road, i think i need coilovers or just cut the mud guard were the rubbing is.
