Painting calipers
Poopensharten
  Golf R
You could maskin tape the disc as close to the calliper as possible to avoid touching the disc with the paint.
Id get a wire brush in about it aswell incase theres any build up off rust, itll make for a better finish aswell :p
  Combo
yeah its good stuff, thats what i used (but in black) and i didnt take the caliper off, just used a smaller brush. make sure you get a wire brush to the caliper before you use paint it to get all the crap off
edit: beaten to it
  F56 MINI Cooper S
yeah thats a good point, i will do that first to get all of the crap off :)
  F56 MINI Cooper S
edit: beaten to it
ok cool mate, did you manage to get all in the nooks and crannys, and did you get a good finish??
Poopensharten
  Golf R
A can of compressed air (or hoover) in about it aswell incase any of the dirt makes it between the brake pad and disc it may score it.
  Combo
edit: beaten to it
yeah it was fine and finished well, only did 3 coats, that was a few months ago and still looks good
  Ph1 172 + Combo van
a wire brush is a must to get a good clean surface to paint on.
any smallish brush is ok really to get in to the hard to reach places.
i done one coat left for about an hour and a half then hairdryered it then painted the next coat then left it over night before putting the wheel back on. than done the other side the next night. i done silver on the calipers and black on my rear drums looks perfect imo!
  F56 MINI Cooper S
i will just stick my wheel straight back on as the caliper doesnt touch the wheel - as long as it doesnt drip down. Do you have any pics of your silver front calipers mate?
Poopensharten
  Golf R
half inch will do it nicley mate, wee tip, before you do paint it dip the brush brissles in a wee bit of turpentine this will make the brissles soak up more paint and make for a more even finish ;)
Poopensharten
  Golf R
Think it may need several hours to dry, id do it night before and give it a good chance to dry, the callipers get some heat when driven!
  F56 MINI Cooper S
yeah it will be drying over night, the air will still get to it even though the wheel is on. obviously it isnt going to be driven until a few days after.
  Ph1 172 + Combo van
here you go very dirty though that is after 2 months need to get in there with some water and a brush to clean them.
and i used the hammered finish silver
thats the best pic i got
and as for leaving the wheel off overnight. i would strongly reccomend it as on my rear drums it dripped and i now have a black blob of paint on the inside of my wheel. although i have managed to get most of it off with a brilo pad!
  F56 MINI Cooper S
looks good, if i start in the morning/early afternoon, they should be half dry by night anyway, ill see how it goes
  Track 172 & Golf R32
will hammerite with stand the heat produced through braking ?? becuase ive noticed that they do sell paint specialised for this sort of thing which as u could imagine is twice as expensive :(
cat171
I used hammerite smooth on mine, it's fine.
Done them all with it, no probs at all. It's all in the prep (wire brushing & a clean up of the caliper)
  Ph1 172 + Combo van
the caliper its self doesnt get hot enough i think! as said as long as you have a clean surface to paint on first and two coats it will be fine. everyone uses hammerite and it is ok!
  F56 MINI Cooper S
hopefully it doesnt rain so i can get out and do them at the weekend, made my mind up and think i will go for silver
Hammerite will be fine as i used it before when painting calipers
  F56 MINI Cooper S
painted my calipers silver today, rear drums black and fitted some clear side repeaters! really please with it, will post some pics tomorrow as ive only just finished cleaning it :)
