Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
they fill fit but they will be illegal....
you need the auto leveling equipment and the washers, the auto leveling unit sits on the passanger rear wheel next to the damper, there is also a computor there that helps to tell the ecu to adjust the beam....
your loom might be a standard loom inwhich you might already have the plugs for it already sitting there you may just need the lights and the leveling unit....
clios aren't legally allowed to tow..... not sports anyway.......and i don't have passengers in the back anyway.........plus, if your cars lowered the auto leveling sensor dosent work properly anyway
No real issues with them, as a technicality they require auto-levelling and washer jets but i dont recall anyone having issues with this come MOT time.
Just make sure you check the lights are not damaged when you buy them.
Dont be tempted by the HID kits as they often are just not suited for the retro fitting and can blind on-coming users.
Other alternative is possibly the projector lights sold by k-tec racing. I guess it depends the look you are after.
Yes the 172 & 182 lights are the same bar the colour of the insert around the light.
The 172s had a darkish black surround and the 182s came with a mid grey colour. there is also a very light grey surround (not many about, but have cropped past them a few times). That is the only differences between them.
They all work the same.
HID Bulb
Starter Pack
Ballast
Levelling Motor.
Just make sure the clips are not damaged for the motor or the lights will be mis-aligned and face down.
