wiring diagrams for a 02 1.5 Dci clio
Car  '52 clio dci
Ever since owning my Clio Dci I have never been able to get the coolant gauge to function! I have tried everything, including:
1) new clocks/dials
2) new sensor
There must be a wiring fault somewhere along the line, but I have checked for continuity from the sensor to the dash and the one signal wire is definitely connected! Im desperate for some wiring diagrams to get this problem solved, as its really starting to do my head in now!!!
Can anyone help me out?
Cheers Lee
1) new clocks/dials
2) new sensor
Cheers Lee
Can anyone help me out??? Im really desperate!!!! Renault won't give me a diagram :(
cooling fan wont work either,,, i have had similar issues with a 1.2 8v turned out to be a broken wire bang in the middle of a section of engine loom...
i'd go as far as to say a diagram wont really help you.. get stuck in stripping the loom back,,
get yourself a power probe then you can back probe all the way along the wire untill you lose continuity
The cooling fan does work, but is constantly switched on and I recieve a fault code for it.
yep break in a wire then... fans permanantly on with it unplugged
you checked the fuses?
I have checked all the fuses near the passenger dash location, but not the ones within the engine bay.
Strange though, because when I disconnect the sensor wiring from the sensor and apply 12 volts down the fan switch wire it turns on and off when 12 volts is removed. But the gauge signal wire does nothing when applied with 12 volts, both positive and negative. I really believe the fault is loacted from the back of the dials to earth. Thats why I desperatly need a wiring diagram!
hey?? it does what???
it dosnt work like that,, it takes a resistance reading you should have 5v on one pin and earth on the other... that sends a resistance value to the ecu, the ecu then from there controls the gauge and fan seperately
sort of like
sensor -------------ecu----------------fan relay
............................ecu----------------gauge
sort of like
Hmm... Well I found continuity from the signal wire from the temperature sensor to the back of the instrument dials, so what ECU is it going through? surely not the main engine ECU if Im getting continuity ?? I thought the circuit was like this...
Neg Batt ----- ECU ---- sensor ---- clocks ---- Pos batt
___________Fan Relay
