spacers??
Car  172
Can anyone tell me what spacers are used for??? Ive read something about hubcentric spacers but cant really work out what there for. At a guess i would say there used to give the car a wider track so it handles better?? Being that the 172 cup has a wider track than a normal 172 would i be right in thinking that these spacers are a cheap way to give your car a wider stance??
Example. My new alloys wheels needed spacers as they wouldn't clear the calliper. They do make the car that slightly bit wider
this is my 1000 post woop woop lol
ive got two 10mm spacers (one on each side lol) on the back
makes the wheel base 2cm weider and stops my wheels from rubbing.
you simple put a spacer on the back of your wheels and bolt
the wheel on as normal. the spacer would push the wheel out.
i got 2 10mm if you fancy buying a set
^^ it sure is
i've got 20mm on the front as I have 1*2 wings so now the wheels nicely fill the arches
so what are people saying. that the main use is to help you fit aftermarket alloy wheels, and the second to make your car fill the arches more??
if the alloys are the wrong offset you can use spacers to bring them back out.
i have been trying to work out if an extra 20mm on a 172 would make much difference for use on track as well, plus the ph1 wheels look too narrow as std on them.
so for arguments sake, if i put 20mm spacers on the 4 corners of my 02 172, will it give my car a wider track of 4cm?? and if so will it make the car handle slightly better as its wider. something tells me that no it wont but has anyone tried or tested this theory?? also if i did this would i have to redo the tracking on my car or anything
@ Tigger ; find out for example the ET of the Cup Turinis. Compare this to your 172 FF wheels and the diffrence will tell you which spacer is neccescary to get the 172 Cup wide track.
Mind you ; you can'nt just throw on some spacers to your liking + go 2cm wider on each side. (well you could but..) The design of the car has taken account with the ET of the standard wheels, or the other way round.
Going too wide will put more stress on the bearings/hubs/etc.. and it will not handle better . It's possible but do'nt expect a nice/reliable drive..
The 182 for example has the bigger hubs, and to make up the difference the wheels have a ET to bring them back in some more, or so i was told by my Reno specialist..
I'm no expert but i have always tried to get the exact ET of the car design when getting new aftermarket wheels
im not looking to put spacers on my car let alone 20mm on each corner i just simply wanted a straight forward answer to what they were used for that all
I've already asked people here who have spacers on about extra strain on the bearings/hubs etc and they say it's fine.
Just after a subtle difference to fill the arch better. Don't think I'd go any more than 15mm per wheel.
anyway, best is to stay within the perimeters of the design.. sure people with spacers will say it's okay, i would too if i had them on the car ;)
like i said, the 172 FF has a different track-width (about o,5mm each side), only because of the different wheels (ET) as the hubs are the same. Meaning that this much is fine also to use spacers; same principal going on
as straight forward as i could get with my reply m8 :)
wheel-suspension setup is very important.. I've seen (on german tv) the worst accident ,filmed by victims friends on their handy, this was a Golf with Euro style wheels (stretched tyres and all) , the car just went from under him at very high speed trying to race a Porsche on the autobahn. Suspension-tyre-wheel setup probably cost him his life
An extreme example here ofcourse..
Aim for a et 38 offset aka Cup offset. That imo is the best for a Clio Sport being the widest track available factory stock
Not sure what your wheel offset is just now but say its a et43, a 5 mm spacer will get you et38
EG:
et43 plus 5mm spacer = offset of 38 (43 - 5 = 38)
as above ive got standard 172 wheels on 48.5 et and im running 10mm spacers all round and now have the cup off set of 38.5 et feels noticably better imo
plus the wheels sit in the arches better too
from this
to this
but mine doesnt actually have spacers on lol
