Engine Oil Light & Stop Light *FRED*
Car  RS6+ & 40d MSport X5
These both come on when the car is cold :(
Checked the oil level before starting this morning and the oil level was fine but the 2 lights still came on till the engine was at its optimum running temprature!
Also took the oil cap off to see if the top of the engine was 'dry' but it was fine!!
BTW the engine's on 97k not sure if thats relevent..
Any idea's??
Gaz ;)
turn the key and wait for it to say oil ok, then press the wee trip re-set stalk poking out the dials, what does it say??
should be 0000000
if its 0000--- thats ok
if its ------- = bad
clean up the connector to the low pressure switch, apart from that, if the lights go out wen you rev it
oil pumpen ist fookend, dast ist not gud
How did you check it? With a dipstick or just by looking at the dashboard display?
What does the oil level sensor show when you switch her on?
If you press the reset button what does it show? "OOOOOO" or "OOOO--", or "OO----"?
Could be that your level is low compounded by the fact that you're on a slight hill.
coming up ooooooooo
where's the connector to the low pressure switch?
probably need a pic :)
front of the block, you might have to whip off the fuel rail cover
i honnestly can't remember! i think so
the top one is the knock sensor
and the bottom one is the level sensor
a few months of not playing with them and you forget!
Freds right green one. Surefire way to test the pump would be pressure gauge in that port if it looks bad.
mine was doing this randomly. got alex at carlton to check it out and replaced the oil pressure switch (green one) and its fine now. and has been for lots of miles.
so if the switch is faulty will any damage be done if its not replaced?
not too sure myself i was in contact with them about it and got told to check certain things.... and if all was well then there shouldnt be a problem just keep an ear out for funny noises and dont drive hard just in case. did a fair few miles like that as well before i could get it sorted
should be 0000000
went from
ooooooo 3 days ago to
ooooo-- yesterday to
oo----- today
problem?????
I had same problem They went off when i revved car
Renault just said it was the Sensors had gone
£15 for the sensor
£50 For half hours labour
I think you need a new oil pump pretty sharpish, but you it's worth trying a new oil filter first. Sometimes non genuine oil filters dont have the correct non-return valving in them so they dont hold oil when the engine isn't running. This means oil pressure (measured post filter normally) can take a little while to build on startup.
should be 0000000
went from
oo----- today
problem?????
£15 for the sensor
did ur display do the same as above?
what kinda price am i talkin about for both mate?
