Fog lights.
Car  Mk2 ph1 clio
Couple of questions about the Mk2 Ph1!
1. Are the surrounds themselves different for each side or are they the same for example .. will one surround will fit both sides?
2. wiring them into a car wihout them.. do you really need these relays the renault dealer insisten on for £170 .. or can you just wire them in from a 12v supply with an inline fuse?
Any help is appreciated!!
Just a normal push button switch using the blanking plate on the centre console (usualy used for central locking?) or the black plate next to the steering wheel next to the headlamp adjuster!
You'll be fine no need for a relay realy. just remember to preferably wire it with a realy to the ignition switch/headlights else you'll be leaving the lights on one time and drain the battery completly.
if you tell me which relay it is we can sell you a used one.
Any relay realy would work for this. PLus you don't realy need one
