maxogen thats the big doller one isnt it ??
ITG maxogen
Bay looks good![]()
whatisjustis What did you use for the plenum and fuel rail?
sorry but not sure what that is lol
Missing 1 bolt on your engine cover.
Looks very blue otherwise.
ITG Maxogen needed.
sorry yeah removed it before spraying i used halfords matt black high temp engine spray 500ml for only 4 quid, so great mod for 4 quid,
itg then next then me thinks, will this also give a greater power outlet than other brands? due to iys high price
itg pannel filter does this make much difference??
thanks clio luke
alrite luke,jus realised your part of cs,duno if you remember me i used to ride with you down stanground sumtimes?i sumtimes see you in plumbing merchants unal.itg pannel filter does this make much difference??
thanks clio luke
the pannel filter will give no power gain, my car did feel slightly smoother through the rev's tho, less strangled.
most 'induction kits' will actually lose a small bit of power due to heat soak. itg maxogen's are very expensive but they will give a small power gain.
i have always rated bmc cda's for the money.
most induction kits just add noise not power.
why is it you were looking at an induction kit? for power gains or noise gains?
