124 mph in 4th - speedo video
  Black Gold Trophy
well I would have thought peak torque is probably between 3500-4000rpm so it would be starting to tail off anyway, but in fourth gear you have to take into account that drag is going to have a significant affect on the acceleration.
ForceIndia
  Gentlemans spec 200
The 172 engine's torque drops off fairly quickly at high revs, more noticeable after a remap.
  f**ked ph1 172
mine is gutless below 5k with 421's. hoping a 182 manifold will help the torque situation.
Its as bad as having a honda :(
  BMW M135i
Christ they don't half scream out for an upshift above 7k, quick though mind!
High power reletively small n/a engine I don't think you'll get away from it.
Pep
  M2,XJS,S1000RR
lol at the mpg in the 5th gear run!
Is that with an RSTuner?
M
mini-valver
From his last video it's running a Group N map, K-tech stealth, de-cat and V6 airbox with ITG filter.
MarkCup
Wats been done to allow it to rev through to 8k?
R-Sport ECU - off the shelf but gives you an extra 500rpm to play with so it's limited at 7,750.
Not really surprising with how stripped it is, I doubt its alone.
Yup, got the airbag light too but that's it...no emissions light after 95k miles on a decat!
I think there's something wrong with it tbh...I mean...look at this (the video confirms this graph)...it's not supposed to drop off like that is it...
Only realy driveable up to 6,500 if I want to get anywhere in a hurry ;)
Adey.
that torque is quite normal bud. theres only ways to make it hold on further up are cams, itbs head work or a turbo ;), rapid as hell tho pulls very well
if that is the mpg figure on the screen then lol at the fact that i nose dives as you boot it mark!
nice vid though, god my 1.2 is slow :(
jamie
