S1 16v 106 Rallye
				Hi all, sorry if i'm asking a few questions that have already been asked before. I've done quite a bit of searching on the forum but am still slightly confused on a few things.
I have a ph1 172, and am looking at the best performance mods.
Are there any problems when fitting a 182 manifold other than having to change the cat to a decat/sports cat of some sort that allows you to use your 172 exhaust with the manifold.. or is it possible to simply fit a 182 exhaust after you've fitted a 182 manifold? I didn't think there were any chassis differences under the car, but if it were this simple and 182 exhausts don't seem to be mega expensive, why do people stick with the 172 system?
Also, what are the other differences between the 172 and 182? Is it then just the map?
Yozzasport/rstuning remaps - are these simply a chip as opposed to a remap? Because if it's just a base map i'm guessign if you've already fitted a 182 system/manifold/induction kit etc to your car you're not going to get your optimum gains? Confused!
Angelworks 'matched inlets' - whats the difference between the oe 172 inlet and the matched inlet? I saw someone mention gains of 9bhp?
Are the 182 injectors any different to the 172 injectors?
Last one! With all this done (182 manifold, decat, induction kit, whatever else ho9lds the 172 back from the 182, cleaned injectors and a remap) what sort of bhp should you be looking at getting from a rollingroad?
Many thanks to anyone that can help me out here
Ben
Ben
