locking wheel nut fucked
  182
well. my key and my nut rounded off tonight.
worst bit is, its the spinny out edged nuts, so banging a socket on is proving to be a b**ch
any idea's?
not damaging wheel ideas to please
pos weld a extension bar onto it??
  182
i thought about drilling then using them easy out drill bits, the reverse tread things.
only thing the drilling the full lot out. is id have to buy a tap set to clean the hole out properly
Sheila’s’ Wheels’
  Whichever has fuel
Weld a socket to it.
If its got that shitty loose collar on it, its a f**king pain in the ass to remove. Although if its a genuine Renault one, they only made about 8 different types, so if you have a few mates with Clio's, chances are one of them will fit it.
Our old mechaninc in work had a box of 8 or so and guaranteed one of them would fit it.
  182
my mate works a reno, so could get me one, but the nuts to far gone, i manged to get the other 3 off luckly.
welding may be the only way....
  www.renparts.co.uk
you need a small chisel or similar and smack it between the spinny collar and the nut, the collar quickly breaks off and then you can knock a socket on, i do a few a week usually.
Alastair.
  986'S 172ph1+182FF
smash a 9mm socket over the centre bit the onces its gripped on just undo, ive done the last 5 locking nuts with the same socket.
