182 cat question
  4 wheels
do all 182 cats sit fairly low to the floor. because now mines lowered it catches slightly on certain speed bumps and multi story car parks. is there any way is raising it.
thanks
Da
  Less
Yeah they do, the centre mount is crap. You could try tightening this up or replacing it but ultimately I believe it will always hang at a dodgy angle.
Has
  RS 182 - Black Gold
They "sag" along with the rest of the exhaust.
1) To resolve this - replace the rubber hanger near it (wears like the others quickly)
2) Loosen entire exhaust system
3) Support cat with a trolly jack, lift up to desired level (ie, parallel to car)
4) Re-tighten all exhaust clamps and it should sit fairly high
5) Lower jack and itl come down a bit but not much.
Never had any issue with mine after that. The lowest part now is the exhaust clamp!
  4 wheels
thanks mate. ill give it a go when the weather is better. do i get the hanger from renault?
