172 ph1
I have a high mileage car in desperate need of new bushings and shocks, and I'm not a bad driver on the track, but not fast.
Having done 55 laps at the Nurburgring I've had 2 tuition sessions, and at the latest one this weekend, the instructor from www.Rent4Ring.de told me that there's nothing wrong with my line, but I need more track time to work on my driving.
Being in this situation, would I be best served to just buy original Renault dampers or Koni dampers, rather than a coilover set like KW V2 or Bilstein B14?
If you've got the time to understand what I need to work on in my driving, read on.
Compared to the instructor driving the same car (a lowered, stripped, caged Suzuki Swift on R888s), I lacked the confidence to enter the corners at the same speed, and I was not able (dared not) to brake as late and hard, as I was not sure if the car was straightend out enough for me to brake that hard without unsettling the car. As an illustration, in Hatzenbach for example, he is able to enter the first (shallow) corner very fast, brake very hard for a very short time, then take the 2nd, slower corner. I'm not able to give the car enough of a transition time between the 2 corners, so I don't brake, and end up taking the first corner too slow, just to be sure I can make it through the 2nd corner.
