JDM Dc2
Got bored so thought id post up my car seeing as ive been on here a few days posting now and i already know a few people so...
Its a Mk5 zetec s, which i bought last february totally standard...
Heres the full spec and my plans over the next 6 months or so...
Engine;
Weight - 896kgs with 1/4 tank of petrol, lost 80kgs from standard.
135bhp and 896kgs = 150bhp/tonne!
The future mods are;
heres just a couple of things ive been upto over the past 3 months or so...
had a crash on valentines day -
Overtakin 2 vans and a car on the A49 on the way back, got past the 2 vans then the car decided to put its indicators on to go right, so i slammed on, locked up did a 180, bumped up the kerb and slammed into a fence, damaged the front wing, side skirt, wing mirror, rear quarter panel, front grille, needed a new rear beam, needed a new tire and trackin doin, cold feed trumpet snapped off
, or well sh*t happens, gotta love the steely
then there was a rolling road meet at Rs tuning and i was having alot of trouble through pumabuild with my chip si i had to run with cams and no chip or map...
Rather disappointed with the result as were everyone else apart from the standard cars, happy with the smooth curve tho, but ill say it again when i get my chip the power should keep goin UP... lol
119.4 bhp @ 6400rpm, 118 lbs ft. @ 4100rpm at the fly.
96.5 bhp @ 6400rpm, 96.5 lbs ft. @ 3400rpm at the wheels.
They were defo runnin LOW! didnt help that the cars were run in 4th gear instead of 3rd.
heres a pick on the M62 on the way home...
Then started stripping out the soun deadening...
sprayed up -
to be continued...
Engine;
- Re-Built 1.6 16v Zetec SE (at 110.5k 2650 miles ago).
- New clutch, cam belt, fan belt, water pump, all filters and battery,
- Polished & skimmed head,
- Piper 285 fast road cams,
- Collins powerchip,
- Milltek 4-2-1 manifold,
- Milltek hi-flow sports cat,
- Piper cat-back with mid-silencer removed, 3.5" rolled out tail,
- K&N universal air filter with samco induction hose,
- Heat shields & cold feed pipe with trumpet,
- Pipercross oil breather filter,
- FSE power boost valve with silicone vacuum pipe,
- Denso iridium spark plugs,
- Magnecor HT leads,
- Ecotek valve,
- Run on tesco 99 octane.
- Laguna front splitter,
- Single wiper conversion,
- Bonnet raised,
- Smoked headlights & side repeaters,
- Ford towing eyes with stickers,
- Smoothed boot handle,
- Black sun strip,
- De-badged & de-wipered boot lid,
- Removed bump strips, front grill, rear arch linings, spare wheel & jack and fog lights.
- 16" team dynamics pro race 1.2s in gloss black,
- G max -40mm springs,
- Dot 5.1 brake fluid,
- Uprated brake shoes,
- Painted drums black and calipers red.
- Stripped (carpets, rear seats, sound deadening, door cards and inner door skin, radio and speakers, head lining, plastics) and re-sprayed,
- Sparco sprint 5 buckets with runners,
- Sabelt 3-point harnesses,
- Fusion fabrication bolt-in half cage powdercoated red,
- Flocked dash lightened with painted heater surrounds and black heater panel,
- Battery in the boot,
- OMP steering wheel,
- OMP footplates,
- Fire extinguisher,
- 8 ball gear knob,
- Richbrook tax disc holder.
- Toyo T1rs (205-45-16),
- Powerflex polybushes allround,
- Black diamond drilled and grooved discs & EBC Greenstuff pads - got the pads just need the discs,
- AP coilovers,
- Puma gearbox with a Shawspeed lightened flywheel,
- Samco coolant hoses (red),
- Uprated coil pack.
sprayed up -
to be continued...
