P
Philpott
looking to put some 4 pots on my 182?
anyone recommends any?
cheers
cheers
how much and are they a direct swap for standard ones ( are they max discs too?)
Not really necessary. IIRC, cars running in the 24hr races just uprate pads/discs/fluid.
^ WOuldn't think so Warren! Thats a long way!!! Cup racers right a stock set up with uprated pads, cooling and fluid.
AP would be my choice. I have mixed views over the Compbrakes. Didn't help that i had race pads in mine on the road.
im just missing the 4 pots got rest
Twas Icarus's team IIRC.^ WOuldn't think so Warren! Thats a long way!!! Cup racers right a stock set up with uprated pads, cooling and fluid.
For a while maybe. I can't see them lasting an enduro event!!
Fletcher, i still didnt rate them on hindsight. Then again, i paid even less than you and that wasn't a part of a group buy. Shed motorsport were ripping folk off! Once hot they were 'ok' very little feelin in them tbh!
Not 1*2, but the 197 did 24hrs at silverstone, quickest in class, discs didn't need changing once.For a while maybe. I can't see them lasting an enduro event!!
Yes mate, like i said i'm more then happy with mine... I'd like to try a set of AP's out to compare though.
Regardless, it's not relevant on a road car. Can't see any advantage to them.
I have the compbrake B4 kit on my 172, great power once up to temp.
:approve:
I've got the same set-up. I think 5.1 is what most use.ok have brembo h/c's ferrodo ds2500, braided lines just need to change fluid now (what fluid) so should i just forget about the 4 pots? opinions please?
If CL didn't wreck wheels id have a set of these in a shot.The only logical reason I could think of for fitting big ass calipers on a 182, is if they were going to be better at dissipating heat and reducing the chances of boiling the fluid in them. Would this be the case?
I know my CL pads already pop my eyes out and will activate the ABS on hot dry tyres with not too much effort.
Grays track car used to have them on and it give me a headache when he broke it was that agressive.
3 sets of disks to one set of pads too IIRC. Hardcore![]()
Love AP's!![]()
I think 4pots are of limited benefit due to wheels size. Pretty big pad area on the standard set-up, can't go much bigger otherwise the discs won't fit under the wheels! IIRC 4pots won't go under 15's, so a non-starter for me.
Tis true! We did lots of testing and eventualy ran the 08 Britcar 24hr on Standard X85 Brembo calipers, Brembo discs and PF05 pads. We did two sets of pads in total and placed 1st in Class and 16th overall out of 52 starters.
Realisticaly the standard brakes are fine with some aggressive pads. The best reason for moving to 4 pots is that you can get similar braking performance without the need to run such a harsh pad due to a larger pad area.
Any one who is desperate for four pots give it a few weeks as we'll have a kit to fit X85 Brembo Cast Monoblocs to the 172/182 on standard discs. More on this when its released.
M
Sorry, slightly off topic - have you got a silver centre cap in there? Or is it just a funny angle?
wander who has them![]()
Looks like the 172 cup centre cap on anthracite wheels to me too
