TwentyValver Project Thread
Car  ValverInBits
Thought I'd put up a thread and show people what I've been doing with my MK1 over the past few weeks.
a little over a year ago, I'd recently changed from a MK1 Clio 1.8 16v to a Ph2172. I was unhappy with the way the 172 handled. The extra power was great, but I thought the ultimate grip was a total let down compared to my Valver.
A mate suggested that I consider a turbo'd valver. I've never liked the idea that much, partly as I don't trust the gearboxes handling the power.
So eventually I decided I liked the idea of a VAG 1.8T 20v in a MK1.
Theres loads of advantages to the 20v - range of tuning parts, stronger gear box with a tighter shift, better designed engine mounts, oil and water feeds already in place for turbo, not to mention the creamy smooth torque curves most 20v setups create.
Disadvantages of the 20v idea:
Need to fabricate engine mounts
Cannot run OEM ECU without clocks, keys, key barrell, etc etc from original car - Qpeng might solve that but still quite costly.
Need to fab driveshafts
Need to chop and reweld subframe
It's not a cheap option, but then the alternatives arent either
Previous 20v Clios
The first one done was the clio TT by MATTBLACK. The first 20v MK1 was done by flan, who also helped adams_16v with his. So just to clarify.....it's not my idea! A lot of what I've done is a copy of flan's project.
First thing I did after some saving was buy a valver. I really wanted a white one, and I also fancied a 1992. That way when it came to MOT time, I wouldn't need a cat and the emissions test should be easy.
Picked up this from gloucester last year.
Next to my 172
Yes it's got yellow fog lights, and yes, I love em
The car isnt mint. The sills are fairly bad, and there is a section around the O/S rear window that will need a chop and weld due to rust. The arches are clean though. Don't worry, that ariel is coming off. Oh and the turbines are fooking MINT.
20v engine codes
The 1.8T 20v came in soooo many cars. Octavias, TTs, polo, golf, A3, A4, A6, sharan, passat, even the new A5s have a direct injection version of the 20v. There are LOADS of engine codes (like 20+). The best of the bunch IMO is the "AGU" code fitted to early Golf IV GTIs and A3s. It gets a big valve head, larger 20mm gudgeon pins, throttle body pickup on the other side, cable throttle, and a forged crank. So although only 150bhp from factory, it's one of the stronger ones.
I spent a while looking for my AGU, but in the end found one for reasonable money.
Then waited around till Jan 09 when I had some holiday from uni to pull the valver engine out.
This Hub nut bent my breaker bar several times. But I gave it some hammer anger and it came out in the end.
Red coolant..... nice
Looks a lot higher with no engine in there
Then there was a long frustrating break while I finished my year at uni.
20v Power :evil:
They come with different turbos
mine - 150bhp - K03 turbo - eg Golf MK4 gti
180bhp - K03s turbo - eg Ibiza cupra
210/225bhp - K04 turbo - Leon Curpa R, Audi TT
A K04 with mapping will top out at around 280bhp/280lbft. This sounds ideal for a clio. But a full K04 setup (inc manifold) is fairly expensive and I was struggling to find one.
In the end, put in a half arsed bid on a low mileage GT28RS on ebay......and won :eek:
For people who don't know turbos, a 28RS is capable of around 330-340bhp on these engines. I won't run that much, or anywhere near that at first......but we'll see.;)
I then found some brand new jabba conrods for cheap, and thought, f_ck it, I can always sell them on if I don't use them.
Gay/Pic***** photo.
Next to OEM K03 turbo
FINALLY I arrived home a few weeks ago from uni, and made a start...
Renault gear mech out. Won't be needing that.
Started to strip down the engine for a trial fit. Biggest problem, was the driveshafts. They had just been cut by a breakers yard when the engine was originally pulled. VAG hold them in using Torx bolts.
ALL Mine had siezed, fun times :mad:
The little b*****ds just wanted to round off, and worse still we (me and ben-B5 BDJ) couldnt hold the driveshaft still to get the bolts out, the engine would sooner turn over!
Some thinking time later, this happened
Yes, I welded that there :approve: Rig.....
Then we had to beat each bolt with a hammer to shock it a bit and carefully ease it out.
Eventually:
Then It was onto a trial fit
You can see the engine is sitting up on the left a little. This is where it's sat on the subframe
So that bit of subframe had to go
I still chopped more out after this iirc, but you get the idea
N/S Engine mount
The plan was to bolt a golf TDI N/S engine mount (stiffest mount) to the chassis leg of the clio, then fabricate an adapter to mate it to the lugs on the engine.
Firstly I used some box section to create the box that bolts onto the gearbox lugs
With that in place I found I couldnt get 2nd or reverse :S So the grinder came out again
Sorted.:D
Now I needed to bolt the VAG mount to the chassis leg. I decided that I couldnt safely just bolt it straight down, the chassis leg just wasnt wide enough. So this happened.
The 3mm plate reinforces the area a bit and makes a good platform for the mount.
Welded up
Further weld was put on fixing the 3mm plate down. Then shaped the 3mm plate a touch with the grinder and coated in kurust for the min.
Then the adapter was finished off - pics further down
O/S engine mount
Take one standard VAG gearbox mount (99p off ebay)
Bring the bolt holes in just a touch
And bolt to clio using OEM bolts and bolt holes
That'll do :approve:
Engine mount adapters (N/S on left)
I wasnt confident welding these up myself with my very small welder. So I took them to Stable Motorsport Fabrications in Towcester who lovingly stitched them up with TIG and powercoated them black.
Finally the engine was mounted (on two of three mounts)
It's currently sitting with no track rod ends, No ARB and brand new R19 wishbones. This is just to get it out the garage so I can pour a better floor surface onto the garage floor.
The wider track of the 19 wishbones with the standard valver shocks gives awesome chamber. :cool:
How it stands atm waiting for the garage floor to 'cure' or whatever
As for management. I have Emerald arriving in the post tommorrow morning. Can't wait :cool:
Next job is to fabricate the third engine mount. The dogbone/lower gearbox mount.
Then it'll be strengthening the subframe. Think I might get Stable Fabrications involved on that too.
That's all for now.
Mark
looks emense mate great work, will be keeping an eye on this
Thats a great project, look forward to seeing it finished.
Do you have any mechanical knowledge or did think f**k it and just had a go?
good work, hats off for giving it a go.
Are you going to strenghten the subframe where you removed a fair chunk? Looks a bit flimsy to me.
Loving, and I do mean LOVING the mk1's on this forum atm.
Keep it up! :D
About time mate! Seems ages back that you bought the car now.
I REALLY look forward to reading more :D
Edit. 5 stars to you sir, already.
gay engine
Friggin AWESOME turbo though, my personal favourite!! Which exh housing is it?
Sadly it's the .86 turbine. But beggars can't be choosers. Hopefully the top end will be a little sweeter to make up for the extra bit of lag. I know you don't like the engines. But I can't work out why :dapprove:.
Shame.....you were such a nice guy, and now this :dapprove:
My mechanical knowledge is all self taught. I'm doing a 4 year engineering degree, but that won't help with anything like this really.
Fappin awesome!
How did you manage to keep this to yourself for 6 months?!
It was tough. a few know about it.
Yes absolutely. I might be contacting the same people that did the final welding on the engine mount adapters. There will be questions posted on here about how it needs to be strengthened though. I was talking to a mate about it the other day and realised that it might not need to be that strong up and down. As the wishbone is pin jointed in effect it mostly pushes and pulls outward on the subframe. The only up and down force is applied when the wishbone is at an angle. Hard to explain....but all will become clear.
much love whiteley for the ratings :)
Photobucket is "doing a little work right now, your pic will be back soon". So I'd check back in a bit :)
On a side note. I'm completely broke, but I do just have savings left for a manifold. Anyone got experience 20v manifolds? My options list has been shrunk down to this ugly looking thing:
http://www.jbsautodesigns.co.uk/product/2886/garrett-gt28-stage-1-underslung
JBS say they have put a fair amount of CFD work into that, but tbh, I think they are using COSMOS Flow-Works, which I've used, and it lies quite badly.
anyone recommend anything else? Don't think i've got room for a top mounted.
i used a full race top mounted fannimold on the TT towards the end gezza with a gt35 turbo...you'll have room fear none;)
forget JBS....there massive moneys...you wanna get on board with badger bill........AKA badger5 on here...hes god with the vag engines;)
I've had contact with Bill. He seems to do really nice top mounted manifolds that are really too far out of my price range (quoted around £950). I've got tops of £600 to spend really. Top mounted may fit.....my only worry is the scuttle drainage in the middle may foul the turbo, and I don't ideally want to take the grinder to that ASWELL!
The JBS one, is really a last resort. They had a cast one in the pipeline which looked a pretty nice design - under-slung T25 and looked fine. They have since decided that it won't go on sale for another 6+ months while they see how their OEM replacement manifolds do (who the f**k is gonna buy those???) :mad::mad:
I'll give bill another PM on SCN. See if he's got anything cheaper.
Emerald arrived today :cool:
Been sorting through the OEM wiring loom, and labelling up. Need to buy a new crank sensor from VAG if they are not too much as the plug on mine is proper fubared.
Pics when I've got more to report.
firstly yellow fogs... you have issues mark.. :p
Also you should deffo fabricate the VAG clocks neatly into the dash.. would look epic.
As for the turbo... all well and good but you need a manifold and down pipe squire!!!
In reference to one of your disadvantages , oem ecu cannot be used without clocks etc, it is untrue. The standard 20v ecu can be unlocked for a reasonable sum of beer tokens and used with non oem clocks keys etc but then we would not have so much fun trying to blow it up on the oxford ring road :cool::cool::cool::cool:
As for the jbs manifolds mark you know my thoughts on those lot .....
Also what chatter valve are you planning on using ?
And derf those are genuine fia gt2 spec fogs ...
also mark if you would like to use my car fettling facilities the current rate is 1 strongbow for everyday half day your car is here.
