Bit of a question for the Engine Boffins....
  B/G 182 + PH1 Track
Not a expert, but the your current exhaust wont fit on to the 182 manifold,
As for the loom there will be a slight differance, not sure exaclty what you would need to do though.
  B/G 182 + PH1 Track
182 one is 4-2-1, 172 one is 4-1,
Not sure how the end differs all i know is that if you want to fit a 182 manifold to a 172 you need to change or modify the exhaust system.
  ITB'd MK1
if you're changing just the engine, it will fit with minor changes to plumbing (very simple) If you want the 182 manifold too, you will need a link pipe (de-cat or sport cat) from the manifold to the exhaust
  172 Monaco
i would rather just keep my manifold if im honest would that not be possible?
and what changes to the plumbing would be needed?
thanks
elliott
  alien green rs133
the carbon canister also has a different route on 182 than the 172, but with the correct pipe shouldnt be a problem
  Mondeo TDCI 130
Carbon canister...................? I have one of them, in bens workshop somewhere!!!
Sell your broken engine to dave! ;)
Sorry to hijack this post but i am in the same boat as youhad major issue with my ph2 172 and just got a 182 engine be nice to know what i really need to change. It may be the bottom end damage on mine.
P.S have you got 182 engine yet? I will have a 172 top end in mint condition for sale soon if you have not already got your self sorted. Sorry admin / mods not making this into a for sale post.
See this thread here
http://www.cliosport.net/forum/showthread.php?t=438405
  ITB'd MK1
What versions come/don't come with a carbon canister then?
they all did
just a completely different hose. You can leave the canister there if you're worried about tank breather fumes, wont make any difference, just leave the pipe off to the engine. all you'll need then is a piece of hose, and a bung (bolt will do the job) and a couple of jubillee clips, OR just use the 172 ph2 plenum which doesn't have the take-off
