Clio 172 ph1 & ph2 exhausts the same ???
Car  Nissan 200sx stage 3a
Hello All :D
Are Clio 172 ph1 & ph2 exhausts the same ?
Center and rear box mainly ?
Thanks Alex
The back box is the same, the centre section is different, it has a longer piece at the front to accommodate the shorter cat. Its about an inch and a half longer. They are not swappable.
That could be why my exhaust on my ph1 sits under the bumper a bit too much, if it was built for a ph2.
Its very confusing because later ph1s had the twin cat still but with 2 lambda sensors, but it was the same length... But then Ive seen an exclusive that has the ph2 style cat but I cannot remember if it was the longer type identical to the ph2.
