Brake Caliper Bolt
  Meg 230 R26 F1
Can anyone give me a part number or similar for the two bolts that hold each front brake caliper on...the ones on the cars engine side of the caliper. The ones you have to undo if you take the whole caliper off the discs.
one of mine is starting to round off and i don't fancy trying to get that out if it does.
any help will be much appreciated, thanks
  Meg 230 R26 F1
has anybody changed these bolts? is there any special material they need to be made from or will stainless steel be fine?
  Meg 230 R26 F1
they are either 18 mm or 19 mm...i only had a 19mm spanner and that worked fine. its the 2 bolts you have at the top and bottom on the back of the calipers.
thanks for the part number
iimushroomzii
Toilet roll king
  Transit Connect.
They're 18mm thats why its started to round because you used a 19mm spanner.
  RS CLIO 197
try an impact single hex socket on them
on the head of the bolt it will also say something like 8.8 - as long as the replacements are the same as that you will be fine
