lightest ph1 172????
Herr Flick
aka Herman Ze German
what sort of weight can these be/ have been taken down to?
around 850kg if completely bare?
toying with the idea of stripping it and tracking it now!!
rich
stripping is the way forward, mine is half done, all the rear is out but I cannot bring myself to do the front carpet as the road noise would drive me mad for everyday use :(
Mine was/is 879kgs with 1 gallon of fuel in the tank.
Thats with all standard body panels.
can get them a little lighter but not much without swapping to fibreglass panels etc
only pic i could find quickly
My Mk1 172 has
Removed
spare wheel and jack
fuel rail cover
rear head rest
mats
engine hoist mount
boot mats etc
light weight 4.2kg red top racing battery
So should be down around 40Kg give or take
How much do Mk 1 172 weigh in at anyway ??????
My Mk1 172 has
Removed
fuel rail cover
rear head rest
mats
engine hoist mount
boot mats etc
Fuel rail cover binned? Man you must be desperate to save weight!
Redtop racing batteries are more than 4.2kg aswell, unless you have a really small one????
Well it makes changing the oil filter easy LOL
Yes it is the very very tiny one red top 20 so make that 4.9Kg:rasp:
Varley Red Top 20
Recommended for:
Racing cars up to 1 Litre using alternator,
Motorcycles, Pit Equipment
Currently used in:
Sports 2000 Duratec, FF1600, FF2000,
Formula Renault, Westfield, Caterham.
DMS Part No: K770-K017
Voltage: 12V
C/10 Capacity: 13Ah
Terminations: M6 Female
Weight: 4.9Kg
Dimensions (mm) L x W x H: 176 x 84 x 130
Gray's 172 has to be up their with the lightest ones on here surely. Its got f**k all in it.
Varley Red Top 20
Recommended for:
Motorcycles, Pit Equipment​
Currently used in:
Formula Renault, Westfield, Caterham.​
Voltage: 12V
C/10 Capacity: 13Ah
Weight: 4.9Kg
Dimensions (mm) L x W x H: 176 x 84 x 130​
I went for the 25, purely for extra crank power etc.
Fuel rail guard is there for a reason though ;)
well the 20 did die on me last week but had been sitting in the 106 gti for a while .
True but it gets in the way and the weight of it is a lot :D
1059kg's for a Phase 1 is standard kerb weight.
Should you be able to get it down to 850kg's @ standard power itll be around 205bhp per ton with a 0-60 of 5.6 ........
hmmm im so tempted to strip my ph1 now, with my mods (full decat system, matched inlets, pipercross panel filter, remap) what sort of power would that be per tonne if its around 850kg??
rich
Mine is down to about 920kgs now but i've still got quite a bit of weight left in there to remove.
possible areas for saving in mine are
dash out
lose the aircon
remove the soundeadening that is on the roof
remove window mechs and rear wiper motor
thats all i could do now with out buying fibre glass panels, polycarb windows, alloy or carbon bonnet, lightweight battery.
That might be next for me as it does not work
dash out
lose the aircon
