Phase 1 172 sprint & hillclimb car
Car  R53 GR86
Ok fellas
I have started to work on my car for next years motorsport season so I have started a blog, theres not much in it but all that will change over the next few weeks.
If you dont know what hills and sprints are I will put something in the blog when I get time.
One thing I have noticed is alot of peeps seem to be buying these for track work especially silver ones, so not to spoil the party so's mine :)
http://w193tfvhillclimbcar.blogspot.com
Will keep an eye on this :)
Most Ph1's are silver!
Ah that will be why then! Sort of stumbled on a phase 1 as I was after a cup but then realised I would be removing the aircon abs and most of the trim so saved myself a grand or so and will end up with a lighter car.
As said before, I will help anyway I can with any advice you need. Should make a really good Hill car.
keep this thread up to date Colin, be good to see how you progress ;)
If your still interested in those parts let me know.
Chris
Colin I bet you cant get it lighter than Chris's ;)
As low as possible , what have you got and is it the bolt on or press on type?
Thanks
according to my records it's a 4.83, bolt on. I had the box built with the gripper for my hillclimb car and blew the box after 10 miles, it's sat in the garage where I threw it in disgust.
That doesn't sound promising for my box?
Do you still have the diff aswell ?
Where did you use your car at and what did you have done to it, would be very interesting.
Can pm if you prefer.
We used to run a gripper diff in a 5 speed dog box, and we lunched the diff twice, the 2nd time it broke up and found its way into the bellhousing, which munched a twin plate paddle clutch and billet flywheel:mad: All of which are also sat in the back on the garage after being thrown there!
yeah, the complete box is there.
Competed in the National rounds at Gurston, Prescott, Loton, Shelsley, and Harewood, plus the odd pot hunting expedition to Curborough. It's a Mod Prod Saloon.
Anyone else using these diff's had problems with them?
Don't want to spend 2k on a duff product that's going to take the box with it!
How long ago was this as I have been told the early ones suffered with poor quality control which has now been resolved !?
2006, as far as I know the diff was Ok, just the box grenaded. If you're interested in buying I think I'd like to return the box to Coventry to have the experts strip and inspect it, then go from there.
Could be possible as my budget is rapidly disappearing :dapprove:
Good luck with the events mate. We should be at silversone for the RS day too.
ECU relocation looks very neat, good job
See you there then!
Re ecu didn't think that moving it under the seat was worth all the hassle/gain.
Also thought it may pose problems at scruteneering as negative for battery would have to loop out from under seat, just need to fit a yellow cable around airfeed pipes so it's easy to find.
How's yours coming along?
Sorry just noticed your post, I will get one at some point but have not been able to fit it in with my shifts and their workload.
I will try again in the summer if they haven't had a ph1 in as I will have more time.
But I have just fitted a used K-tec stealth for the time being.
Blog updated with Safety Devices rear cage and APD matched inlets.
1st event on saturday at Cadwell park, cant wait!
Good work
Are you going to be at Three Sisters on the 18th April? Il probably come and have a gander if so, only round the corner from me...
