Mustang, S13, AX GT
Ok, this is like a mini project so its not good enough for the projects section but should see a few updates...
I recently bought myself a ph2 172, I got it for a reasonable price with a couple of niggles I need to sort out. For now I just want to tidy it up, when I've got some money I might start improving parts but until then I've given myself a £100 budget to have the car looking good. Wish me luck?
The 1st thing to do was to change the wipers to flat blade wipers, a cheap mod but probably my fav mod to do on any car. £10
Next up was to start refurbing the wheels, all wheels are kerbed and they are quite a state. This is going to be the longest process but I figure I'll show you the start to make a point, to make more of a point this is the spare aswell not one of the actual wheels :dapprove: The others are probably worse, anywho here we are:
1st up, tools for the job. So far I've spent about £18:
Just to make a point of how badly kerbed these wheels are:
Now the tyres are still on the wheels and I'm starting off with 60 grit, so a wee trick I'm using to be able to go at it properly without sanding my tyres down... a strip of metal between the rim and tyre:
After a bit of sanding (this took about an hour so far, and I've done about a 3rd of the rim
Sanding by hand ftl) this is the result, I've taken the pics where I'm sanding to show the difference:
I'll update again when the wheel is painted to show the difference. I'm spraying the wheels satin black and I'm trying to decide if I should try polishing the outer rim or just painting it too. I've also got some 10mm spacers so my cousins going to see if he can get me some longer wheels bolts from where he works and if he can they'll go on aswell. Once this is done I hopefully will have enough left in my budget to get myself a standard spoiler so I can get rid of the handle on the back of my car
