197 Cabasse --> Aux cable help please!!!
  RB 197 fatty
Bought an ipod/aux lead for my cabasse system. Came with some very helpful instructions however i came to a holt!
Basically, after finding the amp under my seat and removing plastics and eventually the big red connector block the instructions show two rows of pins.
The instructions have a row of pins with a plastic grid across them if you like with wires already connected in them. My block matched.
However, the instructions show the second layer of pins are not in a 'plastic grid' and the new aux lead plugs straight into this.
On my block, the second layer of pins are concealed behind this grid thing to seperate the pins so i cantjust push my new connector in! :mad:
Any idea how i do this? cant het the hite grid bit out , dont wanna break the pins either.
HEEEELLLOPPPPPPP MMMEEEEE!!!!!!!!!!!:dapprove::S:(
cheers in advance. NORMY
Gaz_
  Extreme mode
I was under the impression you cant with the Cabbasse?? I take it yours is the 6 disk in dash changer?
Gaz_
  Extreme mode
i'm 99% sure it wont. I know it doesnt work with tune point either
  RB 197 fatty
1 - Pull up the clip holding the connector in place 2 - Slide off the grey cover 3 - There are two strips of connectors - leave the one with the wires in there - this is needed! 4 - On the side of the connector gently prise the stips on the side of the connector at the side of the empty strip 5 - Gently pull out the empty strip 6 - Use a screwdriver to clean the holes out at the bottom of the connector (this isnt totally neccesary, but I found it easier to make sure the new connectors firmly make contact with the pins)
storm force....you my good man, are a f**king hero! you may have just found the missing bit off the instructions i got!
i love you.... im leaving my dinner on the table and going outside to try it, even tho its pitch black!
:star:
  RB 197 fatty
sorted! bit fiddly as i was litterally under the seat!!!
...and gaz..... it works!!!! very clear!
  Ultra Red Clio 197
Hiya I'm having problems with this. I thing I have installed it correctly, enabled AUX ON but it's like my stereo can't even find the cable
