Cigarette lighter socket - no power?
Brookie.
hey guys.
the cigarette lighter socket in my 182 has no power running to it. it was quite dirty from the previous owner so I tried to clean it out with vodka and an earbud, until i realised that the light wasn't even working around the edge of it :S
any ideas? i need to use the satnav tuesday.
cheers :)
  White ds3
pull the lighter housing out and you should see a fiew cables see if thyre loose if not then use a codinuity tester or a multimetre and see if there is 12v on any of the cables. if not youl have to re wire take a 12v switch live of the radio if needs be. but if there is 12v there then you may have an earth fault also take a new feed of the radio. any more info required pm me m8
Brookie.
cheers bud, great reply.
ill have another look at this tomorrow.
ill let you know how i get on :)
