Nafoff
		Re: someph-ing different...........
good attention to detail, as mentioned there is more to be done...
with regards to the scoop, its no lower than the foglight holes which i formally used for an air feed, so positioning isn't an issue, volume will be more of an issue ie that scoop will pull alot more in, i tend not to go driving through fords or massive puddles i am unsure of depth so i should be ok....+ with a decent filter it should help just incase
			there are brackets for the inlet manifold that are not needed anymore and also carbon canister bit can be tidied
but the work looks a1
being low is it now not a puddle scoop though???
