Help - Cambelt failure!!
  Petrol Blue Clio182FF
Right,
My car is a 54 plate Clio182 thats currently on 52500miles. The alt/accesory belt was replaced at 36k as per the service guide by a Renualt dealer, this was done on 19/11/2007. The cambelt was replaced at 46,038miles on 3/04/2009 by a vat reg. independent dealer. Now, on the way to work this morning the cambelt failed. I called the RAC out and he said within 15 secs of looking under the bonnet that the alt belt tensioner was failing which caused fraying etc which in turn has lead to the cambelt failing. I don't know what levels of damage have been done to the engine as I had the car towed back home.
Do you think I have a case with Renault as they did the initial belt replacement? I'm going to my local dealer tomorrow to see what they have to say armed with the service book, cambelt replacement invoice and the RAC engineers report stating the altbelt tensioner failure.
Has anyone had a simlar problem and got any compensation etc?
thanks
M
mini-valver
I dont think you'll have much luck as you only replaced the belt. I'm not sure what the Renault service manual states as to wether they say the belt alone should be replaced or the whole kit.
Good luck anyway.
  Caterham 270R
Does the cambelts come in kit form only on the clio's ?? If so you should have a case are parts guaranteed for a year ????
If a belt was just replaced probably not
feel sorry for you
Good luck anyway.
It says belt with tensioners in the service guide so guessing its as a kit.
feel sorry for you
The invoice states cambelt kit in the parts breakdown.
M
mini-valver
Thought as much. Did you have the KIT changed or just the belt? Were you advosed at the time to have a kit fitted if you didn't ask for it?
  ITB'd MK1
Aux belt should have been replaced again at the time the cambelt was done so the earlier aux belt change is insignificant. No idea what will have caused it without actually seeing the car, but i have seen it happen before. Likely the tensioner is seized so the belt became slack and wandered across one of the other pulleys and sliced it
Yosemite Sam
  Whichever has fuel
I'm a little confused...
Was the Aux belt tensioner replaced by Renault or did they do just the Aux belt??
It was done previous to me owning the car but is clearly noted in the service history book that the belt had been changed and its with a Renault stamp.
  ph1 black 172
i think you will not get anything either as they say to change the aux belt kit(including tensioners) every 36k or 2 years(which ever comes sooner) yours has unfortunally gone after 2 years and 3 months.
sorry to here your bad luck.
maynard
  ph2 172 track car
Sounds like they just changed the aux belt and then later on the full cambelt kit. If that's the case then possible cause of the problem is aux tensioner failure as this may have not been replaced.
Yosemite Sam
  Whichever has fuel
i think you will not get anything either as they say to change the aux belt every 36k or 2 years(which ever comes sooner) yours has unfortunally gone after 2 years and 3 months.
Parts are only covered by a 12 month guarantee anyway aren't they??
The manual says every 36k or 5 years for the belt.
To replace the cambelt, the aux belt has to be removed as well, likely to have removed aux belt, fitted new cambelt then refitted the aux belt which is not recommnded.
M
mini-valver
I'm assuming the aux belt was done AGAIN, along with the cambelt here BTW. If not, you're well into the shitty bit of the creek.
Alastair.
  986'S 172ph1+182FF
doh, unlucky, renault will tell you where to go as the belt has been off again since they fitted it
  ITB'd MK1
Maybe on it's second belt change or something like that?
say for example it's had a full aux kit 18 months and 10k ago and it's all perfect and i went to do the cambelt, I'd happily just put a new aux belt on if the pulleys are all smooth and quiet, and the tensioner is free moving
maynard
  ph2 172 track car
Fair enough!
Yosemite Sam
  Whichever has fuel
Has anyone had a cambelt fail on a f4r engine? If so, how much did it cost to fix?
I know an old member (No longer on here) had his rebuilt to the tune of £1200.
It all depends on how much damage has been done.
I know the damage has to be assessed first, was just after an idea before I get some quotes.
Yosemite Sam
  Whichever has fuel
I know my mates Megane 1.6 16v cambelt snapped and it dod absolutely no damage whatsoever!
Fitted new belt, off he went! lol.
