remove 172 aircon
Car  172 turbo & BMW 1m
hi,anyone used a shorter belt on the 172 to do away with the aircon
been told you get a gain of between 7 and 10 bhp
do i just use a cup aux belt?
cheers
You'll be needing the cup belt, cup alternator, cup alternator brackets, some niftyness with the PAS pipes to get rid of it. As for expecting 7-10...........no
the guy at a local garage said to use a smaller belt and redirect it and i could use the same alternator and just leave the a/c unit whare it is
I dont run aircon but the pump is still in use via the belt, its just been disconnected,
I was looking to get rid of it altogeather but after some search on here i cant be bothered to run the cup alt bracket and alt
Its just more expense at no gain
if you just changed the belt so it didnt go round the a/c pulley would that not free up abit more power
Most of the "gain" from removing the Aircon, comes from removing the weight though.
You may get 1-2bhp? But as said its more about weight, and cheaper cambelt changes is what im looking at.
You cant use the same alternator iirc? Has to be the cup one?
But 7-10 bhp, i wish!!!
is the unit itself quite heavy?does the heating work ok when you remove it
The aircon system is heavy thats why the track goers remove it, also as said above it makes cambelt changes easier.
The Fans still work. untill you rip the full heater matrix out :o )
And u need a new alternator as well as all the brackets.
Ideally need a cup alternator but all that's different is the outer plastic casing iirc? K-tec managed to modify a standard F4R alternator for my removal
You save about 7-8kg I think (With aircon removal)
The brackets on the cup alternators are differently placed from the normal ones. on the cup i think they are 180degrees apart and the normal is 130degrees
what do people do about the power steering pipe as the sensor on mne hits the radiator with the cup altenator on !!! radiator is currently in pisssseeeddd at the moment due to it not fitting properly
can you bend the pipe without it breaking, or just take the sensor out of it and weld it up , or will the power steering light stay on constantly
Have you bent the pipe salty?
Yes, It's been on for about 5 months now without problem. Just got some silcon and foam over it to make sure initially. Tis fine though. Like croc says it's fairly pony metal but doesn't need to be bent much. At least not on the Ph1, not sure if theres any differences. Speak to K-tec otherwise. They offer the entire package
I re routed my AC pipes.
Not sure it this pic is of any help
why do you need a cup altenator when removing the a/c why cant the standard one still be used
