3m Carbon Application
  Renaultsport Clio 172 Cup
I bought some of this the other day and went to apply it to my gear insert and dash strips but it doesnt stick very well at all.
Is it just a matter of applting it or does the glue require heating or something first?
Anyone else had experience with this?
  LY R26 230 F1 Team
i've done it mate, use a hairdryer - works a treat!
  RB FF 182
You must clean the parts you want to wrap througly 1st.
3M suggest prepping the surface by sanding or even spraying.
I never bothered.
Take the sheet and heat it with the backing still on it to make it softer.
Then peel the backing off, and apply loosly to your surface.
Heat with a hair dryer and strech the vinyl around so you have no rough surfaces.
Trim the excess with a knife once it cools again.
Check my 182 thread, I've just recently done this.
http://www.cliosport.net/forum/showthread.php?t=403327&page=3
Ahh no wonder! I failed like 3 times last night and then ended giving up!
I will have a butchers tonight and post up the results ;)
Cheers fellas
  RB FF 182
It seems liek when you peel the backing off its quite forgiving as its a dry application vinyl [as opposed to wet and squigying the water out after application] letting you repositon it if you make a mistake!
  RS Clio 182
where do you buy the carbon vinyl from, how difficult is it to get it on the dash strips like in the other thread, cheers
I have done my dash strips now, which were p*ss easy, however I took my wing mirrors off today, and for the last hour I have been trying to get the wrap on but it just keeps having creases in it. Its too hard to do on wing mirrors.
Anyone got any suggestions or tips?
Jamie
  Audi B8.5 RS4 & 200
All that CF in the interior looks good. I wouldnt mind a CF centre console on the dash.
I find it easy to fit to straight pieces, however I am struggling getting it around the mirror back
  RB FF 182
I found that it was easier to cut a peice that was much too big and use the excess to create the curves with the stretching.
Then let it cool for about an hour and trim it afterwards as it shrinks slightly when it cools.
I think the perfect thing is having 3 or 4 hands to do it with lol.
Or you cud just get someone to help :p
  DCi 100
Can you do this like applying t**t strips? Water + fairy liquid to lube the surface up and credit card/squeeze all the water from underneith while getting any air bubbles out?
  RB FF 182
Unsure Alex... its supposed to be applied dry.
Theres a lenghty PDF on the 3M site explaining best practise.
On the back of the vinyl, there are air channels to let out any bubbles. They're pretty effective TBH ::)
  Clio 182 arctic
Can you do this like applying tw*t strips? Water + fairy liquid to lube the surface up and credit card/squeeze all the water from underneith while getting any air bubbles out?
nooo!!!. you cant use any water on it, it a dry application vinyl, designed to be used without lubrication. if it goes tits up you should be able to peel off/reposition at least once more. and for anyone that doesnt know heat is your friend. especially if you screw up. eg(please excuse pics)
creased, ruined
i think not
this was saved due to adding a litttle heat. note that this is just some cheap wapping film, the 3m will be much better.
