46" Samsung To Big ?
I did exactly the same as you when I bought mine (nearly 3 years ago!) and thought it would be too big but after a while you go from straining to get further back, to wishing it was a bit bigger! Lol.
I just had a quick look at what's available, if I'm going to upgrade, I need to go further than 4 inches! :D 50" minimum TBH.
Ive got a 32" in my room at the moment, but my mate has gone off for training in the marines so left me his 40" room. He is back in a few weeks, so ill be losing the 40", and going back to the 32".
Believe me, Id get the 46" in a split second! I might have to. :O
Is it to the side because that's where the joists are?
I'm guessing you fed the wire down the wall? Does it come out a hole at the bottom or did you rag the wall and then re-plaster?
Inside man? Children of men?
Transformers 2?
Took the plung and got a new one 46" Sammy 7020 :) should have got the 50 i think :rasp:
Prize if someone can tell me the Movie ?
Its to one side case 1 its where the Joist are n 2 any closer to the door youd walk into it on the way in
Hole In plaster Board behind TV then the cables all come out a 1 Gang box at socket level nice ne neat :)
Gally you fail with movies !
Transformers 2?
You win...
