Greasy Shock? Vmaxx Coilovers.
Help! My rear passenger side shock appears to be leaking, just looks really greasy :( Should I be worried? :
I checked the other side and its completely dry, so what does this mean if its greasy? My initial reaction is that the shocks gone, but its not a standard shock its a Vmaxx shock that comes with the coilover set so I'm not sure why this would be the case, I've only had them on about a month, albeit second hand.
i would say its leaking, mine failed m.o.t. like that (it was standerd though)
defently worth taking off and checking imo!
Yea its the rear passenger side. But how will I go about getting a vmaxx replacement shock.
You will probably need to go to them direct, are you running the car super low? Im sure they wouldnt like that to much!
No Im not running it super low, It is quite low, but its not even on the lowest setting on the rear adjusters.
I'm going to take it fully off and check it over in a bit.
And because I got them second hand who do I contact?
