OK, so i wired my new crank sensor in, in the effort to get consistent error free trigger readings again (they most important sensor on the engine afterall). My soldering iron is so s**t making it impossible so i bought a new one, did the final bits of soldering and heatshrink'd it all up.
I wasnt actually going to work on the car today, i bought a battery on ebay on wednesday evening with next day delivery and it didnt turn up today... so was a bit gutted tbh.
THought f**k it ill rob my mums again just to get it running, got that lad out and smashed it in PNX, annoying as f**k to drag my computer outside aswell to check its all ok and working properly.
The setup... Computer on the deck loom all over the place
I was fooking delighted to see the RPM gauge on Megatune reading a perfect crank signal, so i quickly smashed on the injector plugs, and the coil pack, (all 3 coil pack wires twisted together by hand naturally bodgetastic
Gave her a crank and couldnt believe my life when it flew into life with no hesitation at all, the idle was screaming away at about 2000rpm (i had adjusted the idle screw last weekened to help it start better).
Immediatley switched it off and adjusted the screw, idle is quite lumpy, i still need to retime the engine one last time. But anyway, the camera baffles the noise a bit, it honestly sounds wicked in real life, better than my old F7R on bodies IMO. I was shocked at hell well it revved up aswell (it used to bog on my F7R but it was never mapped to be fair),
Forgot to put on the camshaft oil seal end caps = oil f**king everywhere
Anyway the vids, they arent impressive, i have no coolant system linked up yet so any engine starts i have to keep brief to prevent damage. It sounds a lot better in real life trust me.
Very first start.... (nothing interesting)
Idle adjusted to around 1000rpm and a few little revs
Few more revs..
Oil pressure was trough the roof and sat at a very high level on fast idle dont know how much exactly as i was jumping around like a kid at the time but it was more than the F7R aswell.
So to do.... Attach all bracketary, re-tape looms and complete valver loom. Attach a new throttle cable, MOT, Tax, Remap e.t.c
