Ph1 172 Headlights not working
Car  PH1 172
Realised last night my headlights have stopped working :(
Have checked the fuses in the dash next to the passenger door and they are fine. Is there another fuse for the headlights under the bonnet or anything else to check?
Bit strange both bulbs should go at the same time and one was not long ago changed :-/
Side lights and main beam work fine.....had to drive home with my sidelights and fogs.
Thanks
Tel
There is relays under the glovebox. Look in the renault manual if you have one tell's you where everything is.
Didn't know there were relays under there...don't have a manual :(.......if you have one or know of where the headlight relay sits under there that would be great mate?
Does the green tell tale light come on on the dash?
If not its fuse/feed related.
If it does, its more than likely 2 bulbs.
Yeah the light on the dash comes on.
Cheers for the replies all hopefully its just the bulbs.........what bulbs are they as I will order some as I won't have a chance to get to halfords what with work?
