new discs and pads for my 172 cup which ones?
Car  Trophy #392
My brakes on my cup are shocking! I think the previous owner tried fitting new pads and there too small, I want some updated brakes but don't want to spend crazy money. If anyone can send me a link to any that are direct replacement I would be very grateful
Thanks to anyone that replies
Brembo hc's, braided lines, ds2500 pads (think thats what there called) and decent fluid will be all you need for the cup
Brembo hc discs up front with oe pads (something stronger if you'd rather) and oe discs and pads on the rear.
Ds2500 are about £90. If you don't want to spend that sort of money, then the ferrodo dsperformance ones are pretty decent for the cost.
Disks, Brembo HC (or max if you want them to look a bit better)
Braided hoses, HEL is what I've bought from camskill but kam racing have these http://www.kamracing.co.uk/index.ph...ke-lines-choice-of-colour-clearance-deal.html
And fluid, ate super blue is my choice. CL also make very good fluid (pads too for that matter)
I had the Brembo HCs, DS2500 pads, HEL lines and castrol super response fluid on my old 182. Great set up, very recommended. Maybe a bit overkill for pottering around but if you like a good blast or track work then definitely use this set up.
I mainly just have a play with other cars ( a golf at 120mph and I beat him :))but feel I have a disadvantage as the brakes are that poor I have to brake early I'll probably
Just get the pads and discs will this do the trick
You think?
